Frame swap
Discussion in 'Chassis & Suspension' started by The Pack Rat, Oct 16, 2007.
  1. The Pack Rat
    The Pack Rat Member
    LaGrange, Illinois
    I have a 1977 K5 Blazer that needs a new frame. What years were the frames interchangable? I think it was 1973-1991 but I just want to make sure
  2. The Pack Rat
    The Pack Rat Member
    LaGrange, Illinois
    Will someone just give me some sort of reply. I've made 8 posts and no one has replied to a single one.
  3. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    There was a slight change in frames in '76 or '77 for the floors between the front and rear seats. I think you need a '77 to '91 frame.
  4. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    I try to help you out do not know the Blazer frames that well if there like the trucks lets say 77-80 now did the frames from 81 -91 get a little bit lighter and change body mounts from the 73-80 years. if you want every thing to bolt right up with out any mods then I would say stay with the 77-80 if you do not want if factory correct set up do not mind a few mods and tweeks go with the newer. That as much help as I can be unless your talking some inner or some of the front body parts. Good luck let use know how it goes or what year you use .
  5. The Pack Rat
    The Pack Rat Member
    LaGrange, Illinois
    Thanks for the help everyone. Now all I need is a donor truck.
  6. The Pack Rat
    The Pack Rat Member
    LaGrange, Illinois
    I still need a donor truck, does anyone have one?
