Front Brakes are done!!
Discussion in '1947-1954' started by kg4mon, Jul 11, 2007.
  1. kg4mon
    kg4mon Member
    Pineville, Ky
    Hey Guys, I've been working alot lately and took a few days off last week to work on the 52'.:D I put disc brakes on the front and have removed the rear end and working on the trans. I found a tailshaft for the 4 speed that will make it a open driveline just don't know if I will use it or not.:confused: In the next few weeks will have a lot of extra parts if anyone is interested. This truck only has 37k miles on it. As soon as my new camera comes in I will post some pics of my trucks and car. Waiting on the rear end conversion from CP right now. I think it's on backorder been over two weeks.:mad: hopefully it will come in the next few days.
  2. Zig
    Cool Beans!
    So did you go 6 lug or 5 on your disk brake set? If you went 6, are you using stock wheels or sumptin' fancy? Sounds great! Can't wait to see this ride of yours!
  3. kg4mon
    kg4mon Member
    Pineville, Ky
    5-lug
    I went to 5-lug and bought some American racing 17" torq-thrust wheels and put them on 255/55/17 tires on the back and 215/55/17 on the front. It should look good. :D
  4. Zig
    Now you can go to this site:
    http://www.richmondgear.com/101032.html
    and see how that 373 axle will do at different RPMs~ (Thanks Aimless!)
    The wheels sound great! I'm torn. I thinks I'll end up using my stock 16s, G-caps, trim rings (need to get), and W-I-D-E whites!
    (unless the disk setup won't allow me to use the stock wheels...)
    Sounds like you're making headway! Keep up the good work!
