Front mount 235 replacing a side mount
Discussion in '1955-1959' started by vhpeddler, Apr 19, 2010.
  1. vhpeddler
    vhpeddler Member
    putting a '60 235 in a '57 3200, what is needed to make the front mount work? Current 235 has side mounts.Thanks
  2. Larrys 48
    Larrys 48 Member
    Spokane, WA
    I took a '57 side mount 235 and put it in my '48 front mount. I had to drill a couple of holes in the bottom flange of the timing cover plate. Our host sells a 235 front mount for a '47-'54. I don't know if the front cross member on your '57 is in the correct location and is predrilled for the front mount. There are some decent posts about this if you search our forum. Good luck.
  3. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    the cross is drilled for the front mount.there should be no problem.
  4. vhpeddler
    vhpeddler Member
    Thanks to you both for your input. It is greatly appreciated
  5. dado
    dado Member
    Bogart
    Good luck finding a new front mount should you need one.
  6. Larrys 48
    Larrys 48 Member
    Spokane, WA
    This post had '57 front mounts available
    colettesbro
    Registered User
    Posts: 175 235 front motor mounts available
    Quote:
    Originally Posted by dado
    Well here is a photo. This mount is exclusive to the '60-'62 with a 235. This is the only year this mount was used. It has been discontinued for quite some time. No one has it. If you have one, put it on Fleabay, and you will make big bucks. I think I found one in a dealership; we'll know when it gets here.
    If anyone is looking for these 235 front mounts, I have a few available from trucks I have parted out.
    Thanks,
    Brian
    cell 507.456.3625
    __________________
    Your wife called and said
    "buy whatever you want" !
