Front Wheel Bearing Confusion
Discussion in '1947-1954' started by sleepindawg, Dec 6, 2013.
  1. sleepindawg
    sleepindawg Member
    Topeka, Ks
    Hello everyone,
    My name is Tim and I have a couple of projects (1950 3600 and 1952 3100) going right now and I'm confused about front wheel bearings.
    On the '50 3600 I am swapping in an extra front axle from a '53 3100 series. This axle already has 1954 car 5 lug hubs on it.
    Now is where the confusion comes in to play. I am wanting 6 lug on the 3600 and have access to 58/59 chevy 6 lug truck hubs and differentials. When I was checking for tapered bearing kits from our host they split the years up like '41-'57 and '58-'59 and upon checking other retailers for the kits they are listing '47-'59 and '49-'59 depending on inner or outer.....
    Does anyone know if I can use the '58-'59 6 lug hubs on my '53 3100 spindles? If I can, which bearings would I order?
  2. sleepindawg
    sleepindawg Member
    Topeka, Ks
    Anyone with an idea?
  3. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Sorry, I converted to the five-lug rotors from a Camero so I could have front disc brakes. I don't know any part numbers for six-lug bearings.
    Damon
  4. Zig
    Hey Dawg~ I've been on this site quite a while, and I must admit your question seems to be original.
    There's been m-a-n-y questions about front wheel bearings/combinations, but I can't remember a question like yours.
    Have you done an advanced search on this site for "wheel bearings"? Maybe someone before I joined has done this and posted info.
    Good luck!
  5. Bill Hanlon
    GMC Master Parts Book shows the same part numbers for front wheel hubs, inner and outer bearings on all 1/2 ton axles (NOT 4 wheel drive) in 1952, 53 and 55.2 through 59. I don't have 1954-55.1 documentation, but I'd bet Kook's life that they are also the same.
    For some reason the grease seal number changes between the early and later trucks, but a National 6064 fits both hubs.
    I have personally used a '52 Chevy 1/2 ton hub on my '57 GMC.
    Hope this helps.
    Now for a little self-promotion: I'm going through my spares and have found something you might want.
    I have an unopened set of 1/2 ton roller bearings and seals from our host that I'd let go for $75 + shipping Current price at our host is $120. Or if you'd prefer, I have an unused set of ball bearings for the same truck at $85 + shipping ($162 at our host). I'll add a set of National 6064 seals for another $5 ($14 at our host). Offer good to Tim only until noon 12/12/2013, then anyone else who asks. Sign up starting now.
  6. sleepindawg
    sleepindawg Member
    Topeka, Ks
    Thank you Bill, but as luck has it a buddy of mine just sold me all the leftovers (frame/ suspension and everything but the cab and front clip) from a 1952 3100 he's sitting on a "mudder" outfit (crindge). It even has an extra set of hubs that were in the bed.
    Tim
  7. sleepindawg
    sleepindawg Member
    Topeka, Ks
