Fuel gauge
Discussion in '1973-1987' started by Alex Ayala, Apr 16, 2009.
  1. Alex Ayala
    Alex Ayala Member
    FT Worth TX
    Hey everybody! Quick question, my fuel gauge is working but when I fill the tank it marks WAY past full and when it's empty it shows about 1/4 full. Is this the gauge or the sending unit? How can I check it?
    Thanks in advance,
    Alex
  2. GMC Guy
    GMC Guy Member
    Livermore, CA
    hey mine does that too, it'd be great to find out why...
  3. David Hall
    David Hall Member
    Chesterfield Va.
    That would be the sending unit. If your going to pull it to check it, Might as well install a new one ( $45.00)
  4. GMC Guy
    GMC Guy Member
    Livermore, CA
    so that means pulling both fuel tanks, and just replacing the sending units?
  5. chevysrule454
    chevysrule454 Member
    feul problem
    I had this same problem and i had to bend the full and empty tabs on the sending unit as from years of bumping they bent and changed the gauge
  6. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Check for bad ground first on the top of the tank or the tank to the body gorund .!!!
  7. bodycount
    bodycount Member
    yeah check your connections, and clean your sh!t up it should work fine, mine used to read empty whem 1/2 full and 1/4 when half full i just cleaned everything and rewired some stuff it wouks fine now
