Fuse box
Discussion in '1947-1954' started by ADtije53, Oct 16, 2007.
  1. ADtije53
    ADtije53 Member
    Since I upgraded my truck to 12V and installed a self regulated alternator, I decided to make a modern small blade fuse box. I used an old voltage regulator, removed the guts and installed 8 fuses, 4 are bypass and 4 are hot from the battery. Here are some photos of the setup, I will clean it up and take more photos tomorrow. I just wanted to share this idea and get opinions.
    BTW: I installed the Chevy Duty 12V wiring harness for alternator, but the only provision for Fuses was for the taillight and stop lamps. Now I have a fuse for the electric fan, for a radio, halogen headlamps, for electric wipers and other stuff.
    Thanks,
    Antonio
    '53 3100 (Going for custom rebuild!)
  2. Zig
    Dat's Bootifull!
    Great job, Antonio! I can imagine how slick it'll look when those wires are rounded up! Awesome! I will be needing to get more info from you, but I'll pm you when I have more time. Looks like your truck is super clean, too!
    Thanks for sharing!:cool:
  3. f4fantm2
    f4fantm2 Member
    Kentucky
    What a neat idea!
    I just installed a fuze block on the firewall under the dash for the same things, using the same wiring harness. I really like the look of what you've done, though, so I think I'll hunt up my old voltage regulator! Thanks for a great idea!
    Bob
    Awsome
    You're very wise to add additional fused circuits .
    The tailights should have seperate fuses and the passenger side taillight should be fused to the dashboard lights so you'll instantly know if they ever quit .
    Here's a thought ~ you could bundle the harness and run it through a grommet _underneath_ the regulator to remove the wires from the engine compartment altogether .
    Early trucks have an 8 fuse fusebox .
  5. Thunder54
    Thunder54 Member
    Port Arthur, TX
    Very nice, might be the coolest upgrade on an AD we've enjoyed in a while.
    CP ought to copy it and offer it. I used a aftermarket fuse box to enjoy the same advantages.
    Jim
