Fuse Sizes for a 49 3100
markcp
Oct 17, 2012
63
Location
Southern Minnesota
Anyone have a guide to what size fuses goes in the fuse panel mounted on firewall under hood? Putting in a new full wiring harness and connecting to the fuse panel, and didn't have anything prior to go by.
Thank you,
Mark
I'm not sure where this photo came from it is in the truck picture folder from this site.
Fuses & Ratings
6 Volts draws more amperage than 12 volts so you'd want a 10 Ampere maximum if you're running a 12 volt rig .
I always experiment with fuses and run the lowest amperage one that won't blow ~ fuses are easy to change , even @ 0-Dark:30 when it's raining far from home , electrical fires , not so much .
We Muddle On Through.......
Y'know , I worked on one of these fine old trucks ,
ONCE :rolleyes: .
