fuse sizes for added fuse junction block
Discussion in '1955-1959' started by Focus, Aug 28, 2007.
  1. Focus
    Focus Member
    This is for the orginal set for 55 thru 59 chevy trucks.
    Radio -------------7.5amp
    Brake LP?
    Fog LP?
    Air conditioner?
    Backup LP?
    Clock?
    Hood Lp?
    Heater switch?
    SpotLP?
  2. dane st. cyr
    dane st. cyr Member
    Louisiana
    Fuses
    I have rewired my truck ( a 55 2nd series 2800) It had no fuse box , It did have a fuse on the heater circuit and its a 15 amp . my suggestion for the rest if you addinga fuse box is to look @ one from a 60's model truck and use the same amp they run for the circuits respectively. I f you have an AC unit, Most run a 25 amp fuse
  3. dane st. cyr
    dane st. cyr Member
    Louisiana
    more fuse info
    you can use use law to figure what amp fuse you will need for most however the fuse boxes on most are marked or you can find it in an electrical manual for Chevy trucks.:D
