gas milage
Discussion in 'General Chevy & GMC Pickups Talk' started by 74sbc, Sep 11, 2005.
  1. 74sbc
    74sbc Member
    graham usa
    hey with gas as high as it is, it is really a burden to drive my truck. i have a built 350 600 edelbrock carb, and am looking into getting my carb re-jetted and re-mettered for better gas, afterwards, i would like to get about 10-13mpg. right now i get about 5-7mpg. on the highway.
  2. brit 50
    brit 50 Member
    Essex England, the motherland
    hi, you wanna talk bout high gas prices!!! over here in england its over ?5 per gallon!!!!!!!!!!! i will let you work out the dollar pound rate but i think we beat you hands down for being ripped off
    he may have made the earth and heavens in 7 days but it must have taken a little longer to make my truck!;)
    ________
    V70
  3. drabo
    drabo Member
    Patrick AFB, Florida
    You might want to look at a gear change or 700R4 swap. It is a little expensive but you will really see the diffrence.
  4. chris
    chris Member
    austin texas
    i have a 454 engine and a 700r4 transmission and i was wondering how many miles do i get a gallon
  5. Sledge Hammer
    Sledge Hammer Member
    Pittsburgh Pennsylvania
    When people ask me what kind of mileage I get in my 59 Apache, I say,"Who cares?" I don't drive it for the mileage. The 350 with Muncie 4 speed doesn't help either.
  6. steve53
    steve53 Member
  7. Chevy79
    Chevy79 Member
    Well I have a built 454, punched out to 468, 750 carb, Rv2 Cam, Turbo 400, 33 inch tires, 410 gears. At 60 mph I get 12 miles per gallon. This on a 79' 4X4
  8. dvalentine
    I had a 305 with a 2 barrel carb hooked to a granny 4 speed with 3 : 70 rear in my 64 C10 panel. Best mileage was around 9 mpg.
    Swapped to a GM HO 350 crate motor and 700 R4 trans, left the rear alone.
    Best mileage so far ? How about 18 around town and 21 on the freeway.
    The GOOD thing is, the truck "feels" the same around town as it did before because of the 1st thru 3rd gearing.
    I have a ZZ4 in my 37 with a Tremic T5 trans with 3 :50 rear and get 21 on the freeway at a 70 MPH average.
    Gotta love those overdrive transmissions ! ;)
    Val
  9. 283 man
    283 man Member
    Bentonville,Arkansas
    My 2007 Chevy Truck will run on E85, reading a artical in a truck magizine last night about add on part for older motors to run on E85 it was pretty interesting to read.:rolleyes:
  10. billydonn
    billydonn Member
    Omaha, NE
    Be it manual (Tremec) or automatic (700R4)... it is insane... well unwise anyway... not to have OVERDRIVE! Not only for mileage, but for quiet in the cab and for engine wear. Sound level in the cab at 3100 rpm is much higher than at 1900 rpm.
    The only reason you might NOT need it is if you don't ever really go anywhere.
  11. vwnate1
    Raising Fuel Milage
    Gear Vendors makes a nifty overdrive to put onto most any slushbox tranny
    I always select my tires very carefully to be tall and not any wider than necessary as that helps more than you'd think by both reducing rolling resistance and reducing engine RPM's at all speeds .
    I'd love to see 15 MPG out of my '49 3100 with Muncie SM420 and '57 235 6 banger engine ....
