Gas Tank Install
Discussion in '1973-1987' started by choperules, Dec 13, 2007.
  1. choperules
    choperules Member
    When I bought my truck it had no gas tank. Old one leaked, rusted the brackets, and fell out. I am now trying to put a tank in it. I have the mounts and straps on the tank. When it is sitting on the jack the fuel lines are to short to reach the tank. Once I raise the tank I can't get my hands in there to hook up the hoses. What's the trick?
    Jason
  2. crew_cab1978
    crew_cab1978 Member
    You might want to take the front bed bolts out and loosen the rear ones. Then you can jack the front of the bed up and access the lines from above. If this does not work then you might want to add some rubber hose to lengthen the lines off the top of the sender so you can get the steel lines one securely.
  3. frikenwoodro
    frikenwoodro Member
    this happened to me a few weeks back i unbolted the bed like crew_cab1978 said an just slid it back about 6-8 inch's and did what i had to i wish i had though of this when i pulled the tank out originally ahah
