On an 87 with fuel injection the fuel tank selector valve switches four things, supply line, return line, pump electrical feed, and the gauge lead. Guam52 stated that when he switches to the left tank the engine stumbles and misses. Based on this statement I think the power for the left pump is getting switched. If the pump power didn’t switch, the engine would die immediately. Stumbling and missing are signs of low fuel pressure.
It seems to be common problem with these selector valves that when they fail they will continue to switch the supply, pump power, and the gauge lead, but the return port hangs up blocking the return path to either tank. The electric pump is capable of putting out over 30 pounds of pressure and with the return path blocked off that stresses all of the elements in the supply line. Typically the weakest link in the supply line is that small hose that connects the output of the pump to the metal line that exits the tank because it is submerged in gas all the time. That hose will split causing a low pressure condition. You can elimate the selector valve by bypassing it.
Replacing the selector valve will correct the return blockage problem, but you will also have to replace the hose in order the get the fuel pressure up where it should be.
I may be all wet here, could be a weak pump or flakey valve, but I have seen this problem on a couple of trucks I have messed with.
GonicGM,
I have never messed with a duel tank system on a carbureted truck but base on what you have stated, it sounds to me like the selector valve or the switch is bad. I would try the switch first; it’s less expensive and pretty easy to change.
Hope I don’t sound like a smarta__ or a know-it-all, I’m just trying to help you guys fight the battles that I have already fought.
Don
