Dual Tank Switching Methods by Years
GM used at least three different tank switching techniques for factory dual tank trucks.
1973: had a mechanical valve, dash controlled with cable(s). I'm unsure or don't remember how the sending unit swapped. This setup may have been used in 1974, I'm not sure.
1974 or 1975 to 1980: these trucks had an electrical valve. It was a metal case valve, self (case) ground with one wire to it. The dash switch switched everything. The switch did not have the spring momentary depress like the 81-up. It just clicked to one tank or the other. The valve was a solenoid. It was either energized or it was not. I do not remember which tank was default. Anytime the ignition was off, it would switch to that tank, selected or not. If it was selected to the non-default tank, it would switch back over once the ignition was turned back on. The sender was actually selected at the switch. If you had a faulty tank solenoid valve, you would switch to the other tank, the tank would not be physically swapped but the sender would as the switch was thrown. You would run down the gas till you run out while the gauge never moved. There were obvious problems with these.
1981-1991: these have the plastic valves. Power and ground are swapped at the switch, valve not self (case) grounded. The sender swaps at the valve. If the valve doesn't operate, the sender is not swapped. The fuel gauge will read the tank it is feeding from. The switches for these are two position with momentary spring depression for each, to momentarily energize the valve. It is not constantly energized like the 80-back. Without looking at harnesses, I can't be sure but I believe the 81-86 had a seven wire connector, two power, two ground, sending unit return, left sender, right sender, IIRC. I have an 87 harness but don't remember how many pins the connector was.
