Gear Vendors 350TH Overdrive
Discussion in '1967-1972' started by vwnate1, Feb 28, 2012.
  1. vwnate1
    Anyone use this ? .
    it appears to be *much* easier to install , rather SPENDY though ! .
    Thoughts & comments please .
    TIA ,
  2. ol' chebby
    You can get a 700 for cheaper, bt their stuff is nice.
    Re : THANX !
    I discovered the TH200r4 from a Corvette is a direct bolt in and some even have
    a four hole rear mount plate so I can use my TH350 cross member , , this will cheaper yet (under $600 rebuilt & installed I'm told) so I'm leaning this way right now .
    I see many have looked at this thread but no comments ~ I'da thought overdrives would be very popular with both Hot Rodders and the stocker guys....
  4. ol' chebby
    I love mine!
  5. vwnate1
    Th200-4r
    O.K. , I googled this and spent hours reading and taking notes , I think this is the right way to go , now to find the core as there's quite a few different ones to choose from .
    Apparently the pre 1988 Model year ones don't need any switches to operate the lockup TC , it's done internally , just apply 12 volts to one pin and you're off & racing .
    GM makes a DP , DT brake light switch you run the 12 volts through so as soon as you touch the brakes , the lockup cuts out .
  6. ol' chebby
    Got that also. I got it from Bowtie Overdrives.
  7. vwnate1
    Thank You
    Russ ;
    I'd forgotten what GM Vehicle it came off of so now I know where to get it :) .
    Looks like I'm going to go with the GM TH350-C , that's no overdrive , just a lockup TC on a built TH350 three speed slushbox .
    Only one wire hookup , I used to have an old British Leycock overdrive switch floating around , I'll use that as it looks neat and is definitely period correct .
    How can I best clean the tranny cooler in the radiator with the radiator in situ ?.
    TIA ,
  8. vwnate1
    I Pulled TheTrigger
    And ordered up a Phoenix Transmission rebuilt th350-C with 1,500 RPM lockup torque converter just now .
    I can hardly wait to get it in the truck .
    :p
    They're swamped as it's nearly spring so I have to wait 3 ~ 4 weeks :eek: .
