gears/or chuck needed for 3600
Discussion in '1947-1954' started by 52wasp, Jun 22, 2009.
  1. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Hello all, I am looking for a set of gears (or a complete chuck) for a 1950 3600 3/4 ton AD truck. If gears, need HG code (Detroit gear) 32 tooth ring, 7 tooth pinion (4.57:1). Appreciate all of your help as always. Reply here or PM.
    Thanks, Mike
    Wilton NH
  2. azcarman411
    azcarman411 Member
    Rimrock, Az
    Another option is the 4.10 gears. Bolt in deal just like the 4.56 your looking for. The casting #s are 3934635 and 3883379. 41 tooth ring and 10 pinion. Chris
  3. 52wasp
    52wasp Member
    Thanks Chris. Looking for this for my Dad. The ring in question has 22 mounting holes. Are there are 4.10's available for 3600? If so, I am sure they would be an acceptable (if not preferred) alternative to the 4.57's
    Mike
  4. ccharr
    Most salvage yards should have the 410's.
  5. azcarman411
    azcarman411 Member
    Rimrock, Az
    These are found under early 67-72 3/4 chevys, and its a bolt in upgrade. Chris
  6. 2tons of fun
    2tons of fun Member
    ninja town
    eaton 052 and 072 are killer asles and there more than just 4.10 and 4.57's available. rember to grab the entire chunk to make it a super simple swap.
  7. 52wasp
    52wasp Member
    Chuck assy interchange
    Chris, so the ENTIRE CHUCK ASSY from a 67-72, 3/4 ton chevy truck will bolt into a '50 3/4 ton rear end in place of the chuck assy that is there presently? I just want to be sure before I go looking for one. Presently, no luck locating an AD era one around here...
    Mike
  8. azcarman411
    azcarman411 Member
    Rimrock, Az
    Mike, GM used the same center section to 72. You wont find a 4.10 ratio in a AD unless someone put it in themselves. I found my 4.10 in a 70 chevy 3/4. I have it in my 54 GMC, and is a totaly bolt in deal. Be sure to replace the gaskets on it and the rear cover, NAPA can get them for you. Chris
