General info website
Discussion in '1947-1954' started by put-put, Apr 21, 2007.
  1. put-put
    put-put Member
    Northwest Florida
    Where can i find general info like dwell for a 235?
  2. Kens 50 PU
  3. put-put
    put-put Member
    Northwest Florida
    Is cam angle the same as dwell? IE, 38-45 for dwell?
    thanks,
  4. Zig
    See?
    That's what I mean by Ken knowing absolutely ZERO! Anyone who thought I was really serious with that comment should be slapped upside the hed with a wine-soaked rag! Can ANYONE tell me how one person can find so many useful web sites??? Big bro- you the man!;)
  5. Kens 50 PU
    Yes they are the same
    Cam angle and dwell are the same.
  6. Kens 50 PU
    Quit sucking up!
    Your STILL number 1 on my list:D :eek: :D
  7. vwnate1
    Setting Dwell Angle :
    Remove spark plugs and dizzy cap, connect dwell meter , loosen points adjusting clamp screw , turn on ignition and crank engine , observe dwell meter and adjust points " On The Fly " to 33* dwell . stop engine , tighten clamp screw , install plugs & dizzy cap , start engine , observe dwell , it should be spot on and not vary more than 2* MAXIMUM when you rev. the engine .
    Set timing at or below 500 RPM with NO vacuum signal to dizzy advance can to ball on pointer , dead nutz .(should be no vacuum signal from carby below 900 RPMS) .
    If the dwell varies as you rev, the engine , the dizzy bushings are shot , time to rebuild it or find a good used one on E-pay , I bought a brandy new in the box Delco dizzy for under $50.00....
  8. Zig
    And this is why we will rub your belly as we pass your monument right outside the doors to the AD Hall of Fame! (Good luck yaknow?) Right inside the doors you'll have a shot at rubbing the forehead of Ken. (It is good karma for computer searches!)
    Yes- there are MANY who contribute to this site. If I ever win the lotto, my $$$ will go towards a Hall of Fame, I swear! You guys are helping to keep these relicks from simply being squished and forgotten. Could ANYONE imagine life without the "rounded"?
  9. put-put
    put-put Member
    Northwest Florida
    Mucho gracias!! Keep um running!
  10. 54chevtruck
    54chevtruck Member
    West Chester,PA
    Ha Ken is Zig #1 on your Good list or the Hit list ? He just does not seem to understand you have always been full of knowledge some of it useful, some not useful. But in general terms always full of it :p
  11. Kevin's 48
    Kevin's 48 Member
    Tn
    I'm gonna go with to much time on his hands. Thank God for that though, it save me from searchng for hours trying to find something that he already knows.
