GMC 248 CI
GMC13
Nov 20, 2005
Location
Ankeny USA
Hey Gang,
Bought a pair of GMC trucks a couple of weeks ago, a 49 1/2 ton and a 50 3/4 (parts truck). The half ton has no motor but does have a 3-speed. The 3/4 has a 248 with a 4-speed (currently not running but you can turn the motor over by hand...not stuck). Was planning on putting in a later model V8 and manual trans but at the same time I also hate to waste a cool old 6 banger that may fire with a little bit of work (?). I know it's not the rod engine that I would prefer but it just bekons me to give it a chance. What suggestions do you have for me? Was this a good motor in it's day?
Thanks!
Alex
If you are real $erious about your 248 check out
http://www.waynemfgco.com
Start in the history department, then drool over the currently available heads, manifolds, ignitions, etc.
It would cost many times what a 350/350 would cost, but it would be one of a kind.
OOPS .
O.K. , : you're a lucky dog !
Put some oil in the cylinder and adjust the ign. points , set the timing , change the oil using cheapo oil for now , crank the engine to work the oil through and save the piston rings , add fuel and spark and fire that puppy up ! .
It's a _seven_ main bearing , full pressure oiling engine that's good for to-day's freewy speeds and workloads .
_Much_ better than a same old 350/350 V-ate combo (yawn) .
-Nate
