Going Crazy On Timing
Discussion in '1973-1987' started by 86badboy, Sep 11, 2006.
  1. 86badboy
    86badboy Member
    morrisonville usa
    ok i need help..i had my distributor out and back in then back out and the cap on and off and now im trying to get it right again...i have it on stroke 1 i have the rotor pointing towards number one i have the cap lined up and it idles...but...every 4 or 5 seconds a pop will come out of my exhaust and then my carb cough up sum gas. i have moved tha cap i have tried everyting i CANT figure it out...350 sb 650 carb stock distributor...thanks alot..
  2. vincent
    vincent Member
    milwaukee wi
    86badboy,
    I had the same prob before. what happened is the oil pump drive moved. putting the rotor in the wrong position. to fix make sure the motor is at TDC on the power stroke, locate where the rotor sould be on the cap and with a long screw driver look down the hole for the dist. move the oil pump drive slot into the correct location. Good luck. V
  3. 86badboy
    86badboy Member
    morrisonville usa
    i figured my problem out after taking my cap and distributor out 100 times i had 2 wires crossed on my cap no big deal swiched em fired er right up..running like a champ again..thanks
