Good donor axle?
Discussion in '1960-1966' started by TINKERDUKE, Feb 14, 2007.
  1. TINKERDUKE
    TINKERDUKE Member
    CORNWALL, ENGLAND, UK.
    Hello again, I'm looking at buying a 1980 Chevy van with a 350 v8 as a donor vehicle. I Know i could use the engine and auto box plus steering column from it, but also wanted to use the five lug rear axle to replace my current six lug. Does anybody know the width of this axle or whether it will fit under a 1960 Apache panel?
    Thankyou in advance, for your help. Steve.;)
  2. drabo
    drabo Member
    Patrick AFB, Florida
    I think it is the same but you might want to use a measuring stick to find out for sure.
  3. 62 short step
    62 short step Member
    Greenwell Springs, La.
    Measure from backing plate to backing plate on both axles. That should help you determine if it will work.
  4. dvalentine
    It is at least 3/4 wider per side ( 1 1/2 inch total) wider than the one you have. It's not a BIG problem as wheel fitment can be done with the proper backspacing.
    Val
  5. TINKERDUKE
    TINKERDUKE Member
    Many thanks for your help again fellas. I shall try and get some "work in progress" pictures on at the weekend.
    Steve.
  6. Rich Anselment
    Rich Anselment Member
    Needed for a 1960-66 c10 apache 1/2 ton truck complete axle or part.
