Got rid of the chains
Discussion in '1947-1954' started by mobileortho, Jul 4, 2012.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    I've been wanting to get rid of the tailgate chains for awhile now. Stumbled across a set of Ranchero hinges for $1 on Ebay so I figured I'd play aound with it to see how they'd work. The hinge on the left is what it looked like after I shortened it. After alot of trial & error, here's the end result.
  2. Kens 50 PU
    Sweet! How does it attach at the top and how do you release it?
  3. mobileortho
    mobileortho Member
    Hampton, VA
    I'm using a set of Perko lockable latches I found here.
  4. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Great job! Looks slick.
    Damon
  5. Raz76
    Raz76 Member
    -okc-
    Good job but I personally like chains better.
  6. ccharr
    Thanks for those photo's Robert. I really like the look of no chains on the tailgate as the newer trucks have. But also like the old school with the chains being stainless steel, and the way I was taught to hook the chains
  7. Blueflame236
    Blueflame236 Member
    Norway
    Chains + exstra secure latch
    Mobilortho
    This is a very good idea , but i also would keep the chains. Its fully posseble to have both as a double secure when transporting long goods in the back . Old Mazda pickup trucks have these latches aswell. What truck does your latches come from?
    Martinius.
  8. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Slick. I never have liked the look of chains either.
    I used some universal tailgate cables from O'Reilley's. They have a spring that allows the cable to be removed from the bed so the tailgate can hang straight down:
    And some $6.00 rubber latches from Speedway. The nice thing about the rubber is it elastic enough to eliminate the tailgate rattling against the bed:
    Basically the same concept as yours, just a little different implementation, on a little later design truck:
  9. mobileortho
    mobileortho Member
    Hampton, VA
    I wanted a cleaner look and also to eliminate paint damage from the chains rubbing back & forth. I don't plan on hauling anything so that's not a factor.
  10. Zig
    I love it, and your problem solving approach! Great solution for those who don't want chains!
  11. Zig
    I like the stainless, Charles, but~
    Aren't you afraid those chains will ruin your paint job? :D
  12. ccharr
    No, when I drove the truck into Hudspeth County, Texas and back to Ventura County, California, I never seen where the paint got chipped at all, that is why the chains are Stainless Steel. :D
  13. My51
    My51 Member
    Minneapolis
    I also like the look of chains and I used Stainless. What I did to protect the paint was to buy the 3M clear protecter and stuck that where the chains would rub.
  14. Blueflame236
    Blueflame236 Member
    Norway
    Chain hoses give some protection !
    Added sleeves around the chains and they protect fearly anough !
      File size:
      121.5 KB
      338
  15. GrandpaGlenn0
    GrandpaGlenn0 Member
    Missoula
    When these trucks were new, they all had protective sleeves like these.
  16. vwnate1
    Like To See.....
    All this ' out of the box ' problem solving .
    If my chains didn't rattle , I'd worry the tailgate had fallen off.... :D
