I need to convert my head light harness from quad to dual. Looking at the bulk head connector it looks like I can take it apart and remove or swap the headlight harness. The connector looks to be three harnesses, engine harness, head light harness and tail light harness. Does this thing come apart?
Yes this should help a bit. If you any more help I try to help http://bowtieguy.proboards33.com/index.cgi?board=Electrical&action=display&thread=560
Thanks for the reply. I'm assuming that if I plug the dual headlight harness into the same position as the quad everything should work and function normal without any cutting and splicing.
Yes Have you gotten the bulk head off & apart without braking it yet. it's pretty easy just take your time. Slip in the duel head light wiring harness. New head lights grounds plug in the head light ends make sure all the connections are nice and or Clean where the connections are. You know how to take the ends off to clean up the wire end without braking them. good to go.
http://bowtieguy.proboards33.com/index.cgi?board=Electrical&action=display&thread=560 There a post I made on the bulk head & wire ends if can use this or not I post it for you to check out. Pontiac1976
Thats good to hear, I scored the duel headlight harness from a junked 84 yesterday. It maybe awhile before I get to see it work but I'll do a continuity check on all the wires. Thanks for the link and info.
