Header Help
Discussion in '1967-1972' started by lowrollin70gmc, Mar 18, 2005.
  1. lowrollin70gmc
    lowrollin70gmc Member
    SF
    Once again, I am in need of advice. My truck now has the motor and trans sitting next to it, the front clip behind it, and one door at work and one door at home! All in primer/baremetal. And it's committed to a 1000+ mile road trip the first weekend in June.
    What I am wondering about is, I'm putting in a new 350 Goodwrench engine (240hp) w/ an Edelbrock performer intake & carb fairly soon. I am now searching for a set of headers that won't stick below the frame of my truck, as I want to lower it in the near future. So, if anyone has used a set with success before, let me know. And a cheap, quality (that's an oxymoron) set is what I have my eyes on. Or would you advise to sandblast and coat the stock manifolds?
    The truck is a 1970 GMC 2WD 3spd 350/4barrel with standard heads. Any help would be greatly apprechiated.
    Thank you for your time,
    Andrew Trites
    lowrollin70gmc@hotmail.com
  2. 83silverado
    83silverado Member
    HEDMAN ELITE HEADERS HAVE WORKED PERFECT FOR ME IN THE FITTING JUST RIGHT AREA, IF THOSE ARE TO PRICEY LOOK INTO SOME RAM STYLE MANIFOLDS
    THEY FLOW GREAT FROM THE FACTORY. YOU SHOULD BE ABLE TO FIND THEM AT THE LOCAL JUNK YARD.
  3. 58 chevy
    58 chevy Guest
    Call up SUMMIT RACING on my 58 chevy trucks thats where I got my block huggers- summit style -and they fit, sound, even bolted up the same as the hooker headers- can't tell a difference for about $80-100 less.
    Jesse Hazell Chevy Duty Tech.
