Headlights which one
Discussion in '1947-1954' started by Ricos54, Aug 22, 2015.
  1. Ricos54
    Ricos54 Member
    CA
    Has anyone tried lights like these? There's a clear set and a blue set and they are supposed to be 50% brighter than the stock one's. My truck is very close so I need to decide what to buy for front lights. I was planning on getting the headlight with the signal built in, saw these that are much brighter which I like, then I will put the signal back in the original place, in the grill.
    What are you installing in your AD truck?
    Thanks
    http://www.classicparts.com/1941-81...p-Bulb-White/productinfo/54-051/#.VdiHNcRHaK0
  2. ccharr
  3. Ricos54
    Ricos54 Member
    CA
    Those were the lights I was planning on buying in the beginning from classic parts. Don't know if the are the same one's or not.
    Are they bright?
    Does the LED work good for the signal?
    Also did you buy a relay for each light?
    Here's classic parts
    http://www.classicparts.com/1941-81..._10LED-Round/productinfo/54-003/#.VdjVN8RHaK0
    Relay
    http://www.classicparts.com/Headlamp-Relay-Harness-Kit-H4-6014/productinfo/52-298/#.VdjU8sRHaK0
  4. ccharr
    The lights are very bright,
    The led so far works great & I had the old turn signal stay on while the head lights are on and the parking lights still work the same.
    There are 4 relays because I have led bulbs on the rear lights.
    I did not do the work, Steve the owner of Da Rod Shop fixed them for me.
    Hope this helps.
