I have an 81 Scottsdale and I was wondering if any of you have ever changed your lights to where you run 2 headlamps versus the stock 1 headlamp. Thanks for any info you can give.
Sorry I can't be more specific, but I have seen conversion kits that give you the newer 2-light lamps in place of the single lamp. Thery're out there, but I can't remember where at the moment. I'm contemplating doing the same for my '74 stepside, so I'll come back with info if I find the kit. Good luck, -bZj
You have to get another radiator support out of a four-headlight model, it doesn't matter what year I don't think (81-87). It should bolt right in and provide youwith the opening for the other headlight. Then you'd have to get your lights and wire them up. You might could find a whole assembly in a junk yard, but if it's not an 81-82 you'd have to find the right bezels to go around the headlights, unless you're not worried about it.
