Heat Plate for the Fenton 235
Discussion in '1947-1954' started by 1st49Chevy, Sep 11, 2013.
  1. 1st49Chevy
    1st49Chevy Member
    Ft Worth USA
    I recently installed the fenton headers with the dual carb setup in my 49 chevy truck. I have one question about the heat plate. I was able to find a heat plate with only one port with the heat tube. Do I need the heat plate with both ports or can I get by with just one. if both ports are needed can I tee off the other one or do need to the plate with two holes? I was not able to find a heat plate with 2 holes. your help is appreciated.
  2. ccharr
  3. DeadZoneTruckin
    DeadZoneTruckin Member
    You should be OK in the DFW area with just one tube.
  4. 1st49Chevy
    1st49Chevy Member
    Ft Worth USA
    Thank you guys for the info and knowledge I will go with the one since its already installed. thank you
