heater control switching
Discussion in '1973-1987' started by towman1970, Feb 14, 2006.
  1. towman1970
    towman1970 Member
    marquette united states
    i got my heater to blow air but now i cant figure out why it wont switch the control from defrost ,heater, and vent. could it be vacum? if it is where do i start to diagnose it.
  2. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    The first place I would check for a vaccuum leak is in the engine compartment. Look for the vac booster and follow the line(s) to the engine and firewall. Then check the back of the controls to make sure everything is tight.
    Hope this helps
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    do you have AC/ in truck
    Does your truck have AC/ if not then it will not be vac, it would be cable for the heater box under dash.
