RE: heater core Leak
[updated:LAST EDITED ON Jul-17-05 AT 03:54 PM (CST)]my heater core will not stop leaking, I've had it fixed, put alumi-seal in the radiator.. . .
it's not the stock engine, it's a big block.
is it possible to run these cores with that engine.
Does anybody make a replacement that will fit my heater assembly, or just a complete swap out?
My heater doesn't use those two holes oriented horizontally on the side of the firewall, it uses two holes oriented vertically about 6 inches apart, closer to the center of the firewall. The unit has 3 mounting bolts that extend between the hoses arranged triangularly.
