heater doesn't blow that much
Discussion in '1955-1959' started by Ricky, Apr 28, 2009.
  1. Ricky
    Ricky Member
    the Netherlands in Europe
    Hi,
    I'm new on this forum, i am from the Netherlands so I hope you understand me.
    I have a 59 Apache 1/2 ton. I replaced the heater motor and the fan, but it doesn't blow that much on my front window. How is that possible? I did look once again, the motor turns the right way, so it blows but not that much. Can someone help me?
    grtz Rick
  2. cowboy357
    cowboy357 Member
    Kansas
    Welcome Rick , Only thing I know is to Make Sure all of Your Ducts are sealed tightlly so Your not loosing the amount of air Moving. Also Make Sure You dont have any Obstructions in the top defrost ducts .
    I,m Guessing You have the deluxe heater with the control levers in the dash ? Even Working Perfectlly They dont seem to blow out enough air to suit Me, But Better then Nothing at all :D . Best of Luck. Bob
  3. 58fleetside
    58fleetside Member
    Boulder, CO
    Make sure the hoses that go to the defrost vents are fully attached. Duct tape works well for me.
  4. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    This topic sounds like a married guy joke !
  5. 58fleetside
    58fleetside Member
    Boulder, CO
    Sounds like Cosmo needs a new heater.
  6. Flashlight
    Flashlight Member
    You know Cosmo, I found that getting a younger/newer 12V heater/blower solved all those problems. Its rare that I have a frosting problem now!
  7. Ricky
    Ricky Member
    I added a new motor a new fan new hoses, taped it and still doesn't blow that much.
    I think I have to live with it.
    grtz Rick
  8. drabo
    drabo Member
    Patrick AFB, Florida
    Does your heater have a resistor on it? On mine there is one behind the glove compatrment. When these get old they put more resistance which in turn puts more of a voltage drop on the circuit which in turn causes the motor to not turn fast enough and not blow enough air. I have this problem on my truck but since I'm now in Florida it's not exactly high prioity. You can take a wire from the blower and straight to the battery and see if it blows hard. Other wise it could be a hole in the ducts or cables not routed right.
  9. Ricky
    Ricky Member
    Hi,
    I don't have the deluxe heater. I have the simple one. I put the wire straigt from the motor to a switch and (with a fuse) to the battery, so there is no resistance between it. I use the black hose sold through classicparts, the black one that has ribs in it. Maybe I need a smooth one?
    grtz Rick
