Heater question
Discussion in '1960-1966' started by sberman, Sep 1, 2014.
  1. sberman
    sberman Member
    Can i use a 67-72 heater assy in my truck at least the engin bay part
  2. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    No sir will not fit...! There were two style heaters for the `64 the deluxe with fresh air which had three levers in the cab and the thrift air heater which had a single pull/turn knob, these two heaters were used `63 to `66, you should be able to buy parts and pieces or complete units...used.
  3. sberman
    sberman Member
    Thank you
    Ill start looking then
  4. Lakeroadster
    Lakeroadster Member
    Central Colorado
    That would be slick to use a 67-72 heater on a 60-66 truck, as related to under hood appearance.
    I guess the question is how bad do you want it to fit? Not trying to be a wise guy, its just that pretty much anything is possible... and in this case it would be slick visually.
  5. sberman
    sberman Member
    I think i will hold off on it not ready to do that much fabing yet
  6. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    So what do you have now Sberman...maybe we can help.....!
  7. sberman
    sberman Member
    Will i guess i have a blank slate. Nothing nada Got a 64-65 c10 lwb with a1970 250 inline 6 and a power glide . But no heater at all which here in so cal is not a big deal except when it is cold or raining. Mainly when i have to defrost the window
  8. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Here`s a couple of pics for you the thrift heater as veiwed from the firewall, and the second is the deluxe, either will work, you will need the tube ducts, heater box/fan, core, and related switch, so from `63 to `66 will work, hpefully you`ll find everything on one truck, the thrift heater has much fewer parts other than the core ports coming thru the firewall as shown in the first pic....
  9. sberman
    sberman Member
    Thanks for the info.
    So the one on the left is all in the cab the one on the right is in the engine bay with just vent hose inside ?
  10. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Correct either case you need the ductwork for inside, there are more thrift heaters in calif, actually more guys want those as to clean up the engine bay, watch craigslist, in my area there were just three ads with heaters complete, all were deluxe, but none showing now....I just checked....! Or start checking your local wreckers, preferably older wreckers that are out in the sticks, you`ll find more parts....!
  11. sberman
    sberman Member
    Found some of the 2nd one in san diego he wants 100 for just the engine compartment stuff
    Is that fair?
  12. Lakeroadster
    Lakeroadster Member
    Central Colorado
  13. sberman
    sberman Member
    Good info there . helped alot. Looks like i want the deluxe heater
  14. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Sberman, so I take it your in Socal, yes I know parts are higher down there, it depends on what you want to pay, to me you should get everything for that price, do you have anything under the dash at all...?
  15. sberman
    sberman Member
    No nothing at all so i need everything been looking on c/l. Cant find anything not even ebay
  16. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
  17. sberman
    sberman Member
    Thanks again lots of good info there
  18. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
  19. sberman
    sberman Member
    Thanks ill join that forum and get in touchbwith him
  20. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    Hi sberman,
    I'm already a member here.... I am looking at a 65 doner and am looking at interest in parts. the plus side for you is that my truck already has a heater... and yes, the doner looks like it has one as well.... Let's talk...
