"Heavy Half"? "Big 10"?
Discussion in '1973-1987' started by Zeitgeist57, Oct 11, 2004.
  1. Zeitgeist57
    Zeitgeist57 Member
    Naples
    Hey guys!
    What components make a "Heavy Half" C-10? Is it a beefed up suspension? Drivetrain?
    Just curious, as I have seen "Heavy Halfs" have 5-lug rear axles just like my standard 1/2 ton. Please inform! THANKS! :)
  2. tech1
    tech1 Member
    you got it on the button heavier suspension and advanced drivetrain.
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Just in the Rear leafs & shocks like a 3/4 ton.But has the reg Diff of a 1/2 Ton
  4. Chevy79
    Chevy79 Member
    My heavy half (83') has 7 leafs in the rear, short wheel base (82') has 4.
    Rear end is probably a 10 bolt, if its a older rig it might have a 12 bolt rear end.
  5. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Well the 12 bolt 8.7/8 went from 73-81, 81 was the last year for the 12 bolt after was just the 10 bolt 8.1/2. That for the 1/2 P/u's
    73-80 Big 10 came with 8 leafs from GM heavy duty shocks two.
  6. chris
    chris Member
    austin texas
    it is heavyduty suspension and brakes and on some drivetrain if ordered
  7. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    So the Brakes would be 11" or 11"5/32 on the 12 bolt 8"7/8 ring gear 1/2 ton 2WD one or two piece drive shift. The 13" would be the bigger diffs c/k20 up or maybe a 4x4 c10 .
    11" R. Brakes measure 2" wide brake shoe
    11'5/32 R. Brakes measure 2"3/4 wide brake shoe
    13" R. Brakes measure 2"1/2 wide brake shoe
    So far what I been told & seen big 10 were only 2/WD.
    So was it also on the 4x4 1/2 ton too for the big 10?
    The info I have been givening has been for the 1/2 ton 2WD's 12 bolt 8"7/8 ring gear.
    __________________________________________________________________________________________________________________
