Heavy Half Ton?
Discussion in 'General Chevy & GMC Pickups Talk' started by 63GMC, Jul 19, 2000.
  1. 63GMC
    63GMC Member
    If anybody can answer this for me, I would like to know if the Heavy Half-Ton pickups had heavier built axles than a regular half ton?
  2. Craig
    Craig Guest
    The Heavy Half's had standard 1/2 ton axles with 3/4 ton leaf springs.
  3. barried
    barried Member
    My 72 GMC has the Heavy Half Rating and has coil springs but it also has the large trailing arms which I have been led to believe that they made up the difference.
  4. Craig
    Craig Guest
    A heavy half was a 1/2 ton pickup with 3/4 ton springs.Most 3/4tons had coil spring rear axles.But a 3/4 ton would had have a full floating axle.Do you have a any kind of over load helper springs?
    Craig Hager
    tech1@chevyduty.com
  5. Jolly
    Jolly Member
    Is your truck a 1963 GMC? If so have you checked with the guys at 6066 GMC Trucks web site?
    http://www.favorites.com/~jolly/GMCTruck.htm
    I can tell you what model it is by the Vin Number, it should look something like this, 1502 P G 3994 B.
    Jolly
    6066 GMC Trucks
