HELP Krylon hammered paint= crap!!
Discussion in '1947-1954' started by breezy, Apr 6, 2009.
  1. breezy
    breezy Member
    Monett Mo.
    I have my heater box all tore apart so I thought I would paint it up with some hammered look paint. Just looks like silver paint to me. Anybody done this with sucess?? Do you have to hold it far away or close or ??? Pics of yours.
  2. ronaldg
    ronaldg Member
    paint
    rustolium hammer brown is amasingly the same origanel color you can get it at lowes for shure mabee at home depot. hope that helps
  3. sonny42
    sonny42 Member
    atlantic beach,n.c.
    hammered paint
    I have also used rustoleum hammered paint.Hammered bronze is really a gray color.Works real good.Hope this helps
  4. breezy
    breezy Member
    Monett Mo.
    Thanks guys I'll check it ouy.
  5. vwnate1
    Painting With Foo-Foo Cans
    It can be tricky as Foo-Foo can paints don't have any hardeners in them .
    I like to do a good prep then ever so lightly ghost on the paint , waiting 5 ~ 10 minutes between coats for the soplvents to flash off and the paint to tack up so the next uber thin coat goes on well .
    The first four coats will look bad , really bad but the 5th or 6th coat should look pretty nice .
    Then , let it sit in the hot sun for a day or two , I heat the parts in my oven for 20 minutes at 200° to ensure they're fully dried , let cool before taking them out .
    If you research Evan's older posts , I'm sure he's written more and better info than this , he's a professional painter .
