help me
Discussion in 'General Chevy & GMC Pickups Talk' started by krazy_texan, Oct 13, 2002.
  1. krazy_texan
    krazy_texan Member
    Willow Park United states
    is it possible to put a 4spd in the floor in a '71 chevy with a low tranny hump or would i have to change the hump out
    this is what i have in mind,
    Remove the automatic and put the stick then put buckets and a console out of a late model burb
  2. Old gearhead
    Old gearhead Member
    Yes you can!! I have a 1969 1/2 ton p.u. w/ the low hump that I changed to a 4 speed about 18 years ago. I drove it w/o problems for 4 years and put it into storage until this year. I am changing it to a 700R right now, so I am having to repair the hole for the shifter, but it was an easy transition. If you are changing to a truck transmission, a donor truck is your best bet. But if you are changing to a car tranny, what I used was a Hurst shifter and handle designed for trucks to clear benchseats and accomodate the difference in seating position. If you find a truck that came w/ a factory 3 speed, the driveshaft will be the right length, and have the right yoke for a muncie car tranny.-Jeff
