Help please on cab and bed
Discussion in '1960-1966' started by 654x4, Jan 27, 2008.
  1. 654x4
    654x4 Member
    i have started the build on my body to frame. i am putting a 4 inch lift, the 4 inch lift and the body mount brkts are the same brkts. these will be welded on not bolted on. my question is what is the proper space between the back of the cab and the front of the bed
    thanks wes
  2. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    Id Set The Cab And Bed Back On The Frame At The Origanal Stance, Then Make All Your Measurments, Then Lift It And Keep It The Same, Or, Measure How Far Apart Your Body Mounts On The Frame Are And Make The Mounting Area On The Cab And Bed The Same Distance. When You Lift The Bed And Cab Straight Up And Add Brackets Or Blocks, The Bottom Of The Block Should Be Right On The Mounting Bracket On The Frame, And The Top Of The "block" Should Have The Cab/bed Resting On It. Just Line It Straight Up From The Origanal Stance.
    Hopefully this is helpful.
