Help with Master cylinder rod setup
Discussion in '1947-1954' started by cmkruse, Aug 28, 2011.
  1. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Well I have the new bracket and MC installed but the heim joint and rod don't line up exactly. The illustrations on the instructions aren't real clear on the proper order of the bolt, spacer,washer, nut arrangment so I need some help. I checked the CPP site and looked at a couple of the tech articles with little help. They just don't show the hardware installation specifically. Does anyone have a good picture of a working installation. If not what do you recommend. Do I put a washer on each side of the heim or just leave the bolt head next to it with the spacer on the other side? It comes with two spacers but with one it's to far one way and with two its too far the other way, It is better but still not a straight alignment on the rod to MC. I can grind down one of the spacers but I though this was supposed to be a straight bolt in installation.:(
    Any recommendations appreciated.
  2. ol' chebby
    NOTHING is EVER just bolt in, grasshopper. You must learn the ways of the marketing department, young Skywalker.
  3. Bilbo
    Bilbo Member
    Magnolia, Texas
    Well, Grasshopper, I'd put one spacer, and add a couple of flat washers 'till I get proper alignment. Make sure nothing rubs the Heim joint to cause a bind.;)
  4. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    The Force is with me
    Just need new batteries for the light saber I guess:D
  5. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    Follow your heart and your dreams will come true.....:D
