hesitation
Discussion in '1955-1959' started by Dillon Hill, Apr 20, 2011.
  1. Dillon Hill
    Dillon Hill Member
    I just gave the 235 a tune up, cap rotor points condenser plugs wires and timing. It still has a bad hesitation when I give it the gas. There isn't an acellerator pump on the carb, the vaccume advance works fine. ???? Any ideas
    Flat Spots
    Fix the acellerator pump..... ALL Chevrolet I-6 engines fitted to Motor Vehicles had acellerator pumps .
    You didn't mention doing a valve adjustment , this is critical , the very first step in any tune up .
    Did you set the timing to ball on pointer @ 600 RPM ? .
    Is there any vacuum signal to the dizzy @ idle ? .
    These engines were plauged by off idle flat spots from new , that's part of why GM re designed the Rochetser leaks a lot 'B' Series carby at least once every model year....
