Holley 390 or offy 2x1
Discussion in '1947-1954' started by SEVEN0SEVEN, Apr 21, 2009.
  1. SEVEN0SEVEN
    SEVEN0SEVEN Member
    Anyone on here runnin the cillford intake and 390 4bbl i think this is the setup im going to run just trying to get some feed back first think its going to be cheeper then the 0ffy 2 or 3 carb set up
    motor is a 235 think it is a stock rebuild its got a tag on there that reads power pack no cule what that means any info would help thanks
    Just remember it'll run better with multi carbys as the l o n g intake runners will ensure uneven fueling to the end cylinders when you use one bigger middle carby .
    Three Carter YF's is best , more do fine with two Rochester series 'B' carbies .
