Homemade radiator shroud
Discussion in '1960-1966' started by Ratnest, Mar 16, 2014.
  1. Ratnest
    Ratnest Member
    I chose not to spend $100-150 for a new repop shroud and decided to make one. Never made one before, but why not try! My flex fan is about 18 1/2" so I went to the sheet metal shop and ask them to make me a 16 gauge, 21" diameter circle, 4" deep and strenghtened with ridges. That cost me $15. I took the strip home and made my circle and spot welded it. I bought a 5' length of flat strap at Home Depot to make mounting brackets. I used a scrap u-bolt to get around the lower radiator hose. AND..a couple hours later it was done.
    I know it's not professional, but when my welds are dressed and it's painted, it will be good enough for me.
    I sure hope I'm not doing too many posts...but this sure is fun. :D
  2. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Shrouds R Us
    Airflow through a radiator can be maximized only if the entire core is covered by a shroud.
    This ensures that the fan pulls air through the entire radiator surface.
    Some good information can be found here: http://www.jalopyjournal.com/forum/showthread.php?t=814819
    Will you need that.... hard to say? A friend of mine put a bone stock 1990's EFI Trans Am motor, drivetrain and electronics in an early 1950's pickup. No shroud and no fan at all, it never overheated.
  3. Ratnest
    Ratnest Member
    Thanks for your input. I knew that my shroud would not be totally efficient...but hope it helps a little until I find a good/full shroud. As you pointed out, I may not need a shroud at all. This shroud project was the result of being bored and wondering if I could make one. Too much time with little to do can be a problem. Anyway, I'll leave it in place for a while.
    The H.A.M.B website is undergoing an update and I will view it when it's up again. Back to the bed installation today.
  4. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
  5. 66 Truck Drive
    66 Truck Drive Member
    Next to my bench at the shop, Oregon
    That's a sweet fan shroud! I likes! :D
  6. Ratnest
    Ratnest Member
    Thanks guys for the advice, info sites and compliment. As usual, I'm learning a lot "after the fact". It was still fun...nevertheless. :eek:
