Hood brace - 1956
Discussion in '1955-1959' started by chevy56lb, May 10, 2006.
  1. chevy56lb
    chevy56lb Member
    West Jordan USA
    I am doing the hood of my truck and would like to take the bracket off that bolts to the brace going across the front of the truck and has the hood latch plate on it in order to sand and get the rust off. That plate is held by BIG rivets. Has anyone taken that off and when you put it back together what did you use? Thanks for your help!
    Duane
  2. rico_bob
    rico_bob Member
    Harrison USA
    [updated:LAST EDITED ON Jun-16-06 AT 02:51 AM (CST)]Good idea to get all of that apart to get to the hidden rust areas. Rivets can be drilled out and chisled off or gound off if you are carefull with the grinding wheel. As far as going back together, you could use bolts small slotted (with round tops) bolts with nylock nuts. I have used them to replace the big rivets in the chassis before. When tight just fill the slots with filler if you want to "fake out" the on-lookers.... A purist will catch the result and crita-size you but hey to each his own.
    Visit my web site.
    My trucks:
    56 SWB Stepside Small Window
    57 SWB Stepside Big Window
    58 LWB Stepside 2B Ext. Cab
