Hood weight
Discussion in '1947-1954' started by garya, Aug 2, 2005.
  1. garya
    garya Member
    Salinas USA
    does anyone know what the hood on a 54 weighs?
  2. coilover
    With or without the emblem? I'll pick one up and step on the scale tomorrow.
  3. coilover
    Finally got off my backside and weighed a hood. It is a 54 but should be nearly the same for all. 48 pounds.
  4. garya
    garya Member
    Salinas USA
    Evan, thanks for the info. I need to replace gas springs that hold the hood up and needed the weight to order the correct ones. I didn't have access to the hood to weigh it myself.
  5. coilover
    Garya--be aware that the mounting points also figure in big time on the cylinder rate. You probably already know that the closer you mount to the back of the hood the stronger the cylinder needed and much lower rate is required as you move the mounting point forward. This rusty old brain has forgottin it's studies on vectors but any pilot friend or whiz kid could give you the rate needed in a flash.
