Hooking up original gauges after V8
Discussion in '1947-1954' started by Flipper, Dec 12, 2005.
  1. Flipper
    Flipper Member
    Anybody here keep the original gauges after swapping in a 350/350 combo?
    What do I need to make it work?
  2. Bill Hanlon
    RE: Hooking up original gauges afte
    If you don't mind spending some $$$ point your browser at
    http://www.speedometershop.com/enc-pag.htm
    United Speedometer ain't cheap, but they make quality products.
    RE: V-8 & original gauges
    Of course ~ you'll need some threaded adapters (maybe) to connect the oil pressure gauge line and hopefully , it'll spent the rest of it's life pinned on the high end...
    I dunno if there's a hot water port in the back of the block on a 350 , or maybe one in the left head but that's what you'll need =
    a threaded port to screw the temp. gauge bulb into or a bushing then the bulb . it is very simple all in all ,you'll need to find a FLAPS with a good Weatherhead cabinet ot maybe just crawl the scrapyards for a while to find the bushings you need....
    -Nate
  4. dancerman
    dancerman Member
    Atlanta
    Your original guages have a low oil pressure range (for the Stovebolt 6) and an ammeter. I used United Speedometer and got modernized 12 volt original units with higher oil pressure range, voltmeter, 120 mph speedo and all the hookup hardware including wire harness and sending units. It was about $550. but worth it for a nice truck.
  5. volcan96
    volcan96 Member
    Silicon Valley USA
    dancerman,
    Did you have to send the unit to United Speedo or did they have one on hand that you bought/swapped?
    thanks.
  6. dancerman
    dancerman Member
    Atlanta
    [updated:LAST EDITED ON Jan-05-06 AT 08:05 AM (CST)]I called them up and told them my engine info and got a price. Then sent my original units as an exchange. The ones I received are brand new with all the modern upgrades
    http://iserver.chevyduty.com/dcforum/User_files/43bd274c08b40a4e.jpg
