Hopefully correct cast #
Discussion in '1960-1966' started by dado, Mar 31, 2009.
  1. dado
    dado Member
    Bogart
    Dist pad f0629j Block 3769716 Head 3836848 Thanks :D
  2. Kens 50 PU
    casting # on the block indicates that it is a '58-62 235. The casting # on the head is also that of a 235.
    The serial # by the distributor pad breaks down as follows: "f" flint, mi assembly plant "0629" means it was built on June 29th "j" is the designation for 3100 regular prodution.
    Ken
  3. dado
    dado Member
    Bogart
    Thanks again! Who sells a good quality cost effective overhaul kit? Trans was full of water engine seized can not get bell housing off inner bolts blocked by fly wheel going to pull head try to free up from top so I can mount on a stand any words of caution? I have built multiple 305 350 over the years this is the first 235 or in line 6.
  4. Kens 50 PU
  5. drabo
    drabo Member
    Patrick AFB, Florida
  6. dado
    dado Member
    Bogart
    Got the head off 4 of 6 have been filled with water many times appears pretty rough.I wet every thing down with pb blaster I will lightly hit walls with wet or dry 220 try to get pistions out lightly hone & see if it is worth while.will try to past pics later this eve Joel:eek:
