How to fix the ignition distributor
Discussion in '1947-1954' started by wokri, Jul 31, 2020.
  1. wokri
    wokri Member
    Germany
    Hello,
    has someone a picture how the ignition distributor is fixed in the right position?
    Ask
    Wolfgang
  2. Bill Hanlon
    To do it right you need a timing light.
  3. Bill Hanlon
    However, you can get it close enough to run with a test light or a DC voltmeter.
  4. wokri
    wokri Member
    Germany
    Thats clear, but I wanted to know the rough attitude to fix the distributor.
    Wolfgang
  5. Bill Hanlon
    I need to quit this conversation because my knowledge is GMC engines and you have a Chevy. Hopefully another forum member will answer.
  6. Fifthchild
    Fifthchild Member
    rps20200801_094604.jpg As requested here is a pic of a typical distributor setup on a Chevy Thriftmaster. Note that the number one cylinder plug wire is roughly at the 4 o'clock position on the cap and also note the vacuum advance inlet is pointing forward. This distributor is set with the number one cylinder at top dead center and rotor pointing to the 4 o'clock position. Your rotor may be and most likely is in a different position.
  7. wokri
    wokri Member
    Germany
  8. Fifthchild
    Fifthchild Member
    The "A" is advance and "R" is retard in regards to ignition timing. The lines are a scale in 2° increments going from 10° retard to 10° advance. The distributor pictured is set at 2° advanced. Remember this is only a scale used for adjustment purposes, actual timing degrees are set using a timing light with engine rpm set at the proper specification.
  9. Bill Hanlon
    Set the A/R pointer to zero before setting timing with a timing light. That way one can experiment with advancing the timing using the A/R setting and still be able to return the timing to the factory specified setting without using a timing light. My 228" GMC six runs best when set to 6 degrees A.
  10. wokri
    wokri Member
    Germany
    Thank you for your answers! The engine started direct!
