how to mount a 6.0l LS motor into an AD frame
Discussion in '1947-1954' started by 53mess, Jul 4, 2017.
  1. 53mess
    53mess Member
    harriman tn
    Anyone put one of these motors into a AD frame. Any help would be appreciated
  2. coilover
    Done several of these swaps along with LT's and even one LS7. We have our own mount adapter pattern but you can buy them from a number of different sources, just do a search for "LS engine mount adapter". Once these are bolted on then just buy a mount kit for any sbc. On older LS engines a steam tube is plumbed into the upper radiator tank or hose. The *@#&! coolant inlet needs to be changed to a straight facing forward one and the air induction tube for the injection set up will have to be fabbed up; usually involves using an elbow. This is such a routine swap I probably didn't take pictures. Something that might help is a shot of our LS engine lift bar. They are a b!tch to try to hook a chain to.
  3. coilover
    You can see the mount adapter on the side of the block.
  4. coilover
    And a lift bar shot that gives a better perspective.
    55 pu eng bay, LS lift, Int.fuel tank 001.jpg 55 pu eng bay, LS lift, Int.fuel tank 002.jpg
  5. e015475
    e015475 Member
    Phoenix AZ
    There's a lot of ways to do it, but here's what I did-
    Started with some ebay motor mount plates - search "LS1 Motor Mounts". For $20 it isn't worth the time to make them yourself.
    I generally make the motor mount out of 1.5" DOM and use urethane Jeep spring eye bushings for the compliance part of the mount.
    Here's a link to a kit that's similar. GM LS Motor Mounts by Liquid Iron Industries LS1 LS2
    I don't have a high amp MIG welder to weld the mounts to the frame, so I prefer to make a cross member on the bench with the TIG to support the motor mounts that bolts to the frame.
    My engine support to get the engine in and out isn't as sophisticated as Evan's in the previous post. Since I'm almost always doing this by myself, I bought one of these from HF so I can tilt the motor as it goes in without any help
    https://www.harborfreight.com/2-ton-capacity-heavy-duty-load-leveler-60659.html
    I bolt the chain to the holes in the front of the heads that normally are used to mount the accessories.
  6. coilover
    Hey,
    If it gets the job done it's a good tool. We are usually putting engines into places never meant for them and found that it they are hanging by a single chain/bracket that allows them to be angled/tilted/rolled/twisted without binding it makes things easier. This and guide pins are the hallowed ground of engine stabbing.
  7. 53mess
    53mess Member
    harriman tn
    thanks guys been off a few days hip and back problems. But also came across a 49 5 window that i bought and been trying to get it all home
    Zig likes this.
  8. Zig
    Hope you're over your back/hip issues by now.
    You <know> you can't say you bought a '49 and NOT post pictures of it, right? ;)
  9. 53mess
    53mess Member
    harriman tn
    As soon as I get it home been raining here
    Zig likes this.
  10. 53mess
    53mess Member
    harriman tn
  11. 53mess
    53mess Member
    harriman tn
  12. coilover
    Thought I'd check in on your project. Ran across a few pics from a couple years ago that may have some helpful tips.
    1 Tidy mounting of computer/electronics
    2 Air inlet tube and p/s reservoir
    3 Factory column and shifter
    4 Main wire harness through firewall
