I NEED HELP
Discussion in 'Truck Parts for Sale' started by 63 gmc stepside, Jun 23, 2004.
  1. 63 gmc stepside
    63 gmc stepside Member
    hi!,I'm converting my engine from a 305 v/6 to a 350 v/8,tranny wise i,m changing from standard to automatic(th350),my question is when swaping out tranny's do i need to change crossmembers, or what do i do???? Same ? with motor mounts ,what kind of mounts do i need.Please help
  2. PTAirco
    PTAirco Guest
    This group is very helpful, if you have no luck here.
    http://autos.groups.yahoo.com/group/6066_GMC_Truck/
    I am certain you need a new crossmember.
  3. step1958
    step1958 Member
    rose oklahoma
  4. knotts63gmc
    knotts63gmc Member
    ELLISVILLE, MS
    Can't Help With Your Question But Was Wondering If You Have Any Original Hub Caps From Your '63 That You Want To Sell. Thanks, Kelvin Knotts.
  5. 283 man
    283 man Member
    Bentonville,Arkansas
    Check and keep on checking on e-bay on hub caps things change every day on e-bay!
  6. PackRat
    PackRat Member
    Kansas
    I change from a 216 to a 402. Frame mounts from a 73 worked like a champ, after re-drilling the frame and crossmember, and bending the front crossmember bolt tab to match the crossmember. Also, you get the later style though-bolt mounts, rather than the old horse-collar, or center-bolt style.
    You will need to fabricate, or purchase a tranny mount, since you are moving the tranny mount from the bellhousing to the tailshaft housing.
    Just $.02 from my project.
  7. drabo
    drabo Member
    Patrick AFB, Florida
    Simple answer, yes. You will need a TH350 crossmember and mount.
