Idler Arm Questions Need Help
Discussion in '1973-1987' started by Devin, Jan 11, 2009.
  1. Devin
    Devin Member
    Blmfld N.M
    I have a 81 c10 dually i made into a welding rig. I am feeling a bad vib and am getting a rattle on rough roads coming from the front end I balanced and rotated and replaced all tires the only area of abnormall movement or play is coming from the pass. side idler arm could this cause a vibration and noise? please help
  2. David Hall
    David Hall Member
    Chesterfield Va.
    Is your truck 2wd or 4wd?
  3. cowboy357
    cowboy357 Member
    Kansas
    If Your Asking if the Idler arm could be Causing the Problem ? Most Definatlly , If It Has ANY play in it Whatsover up , down , sideways . ANY . Its Not Only Going to cause it to Shimmy , Make Noises . But Pretty Darn Dangerous to Boot. Best Of Luck . Bob
