idler pulley
Discussion in '1988-1998' started by mattpadl, Aug 7, 2014.
  1. mattpadl
    mattpadl Member
    I have a serpentine belt system off a factory 1989 gmc 1500 305 on my classic truck.
    I do not have the idler pully on my setup tht goes on the passenger side between the crank pulley and the a/c.
    If anyone can send a pic of theirs I would appreciate it.
    Would also be helpful to know if there is a spacer or washers or another bracket to mount
  2. Ben@CPOA/TECH
    Ben@CPOA/TECH Member
    Kansas City, MO
    Here is a picture I found of a stock style set up, I have never seen one without an idler arm and pulley. I put an engine in a truck with older style heads but it had a newer block, and I ran a stock style serpentine set up with no problems.
  3. mattpadl
    mattpadl Member
    thanks for the pic. adding the idler should solve my problem of loosing belts on the race track at 7000rpm
