Ignition Switch
Discussion in '1947-1954' started by Andrew Bahnsen, Jan 21, 2022.
  1. Andrew Bahnsen
    Andrew Bahnsen Member
    Hello all,
    I'm just curious what ignition switches you're using on your AD trucks?
    A little background, I have a '49 3100 with a 12v system. I have accessories too that'd I'd like to run without the engine on.
    I tried using this switch: Ignition Switch With
    With this bracket: Ignition Switch Mounting Bracket
    and it was too short and didn't reach the face of the dash.
    Are there better alternatives?
    Thanks!
  2. Bill Hanlon
    The switch you pointed to is not a stock switch because it has 5 terminals including one for a starter solenoid which our generation of old trucks did not have.
    Our host lists Ignition Switch - Original Type-Classic Chevy Truck Parts which I have used successfully. You will also need this mounting bracket Ignition Switch Bracket-Classic Chevy Truck Parts if you do not have one.
    The switch does not come key and cylinder, so you will also need one of these https://www.classicparts.com/1947-66-Ignition-Switch-Cylinder-w_Key/productinfo/53-475/
    or one of these, if you want all locks keyed the same :
    47-51 Complete Lock Set-Classic Chevy Truck Parts
    52-53 Complete Lock Set-Classic Chevy Truck Parts
    54-55.1st Complete Lock Set-Classic Chevy Truck Parts
    depending on what year model your truck is.
  3. Andrew Bahnsen
    Hi Bill, and thanks for you response/help. I didnt even think about stating that I have a 12v system running on my 283ci V8 with electronic ignition distributors. Sorry about that. Does that change which types of switches I can use?
  4. Bill Hanlon
    Yes, you'll need something with a "start" position (may be marked "sol") on the switch. What year truck?
  5. vwnate1
    Waitaminnit ! .
    The switch proper doesn't care about 6 or 12 volts .
    If you retain the foot starter you can use the original typ ignition switch and retain the set back and illumination it has .
    If you're using a solenoid typ starter it's a very simple thing to use two large flat washers ("fender washers") on the pedal hole and mount as heavy duty momentary contact switch to operate the starter's solenoid .
