Info on this 6 Volt Generator 1102701
Discussion in '1947-1954' started by calebroberts, Dec 12, 2006.
  1. calebroberts
    calebroberts Member
    Lyons
    Hey folks, Can anyone tell me any specific info on my generator - 6 Volt Delco-Remy number 1102701? I've been having problems - presumably with the newer replacement regulator and I want to try to find a proper regulator for this generator but I have no idea what its current output is supposed to be, etc. I've already tried looking in three of the parts catalogs that are on the old Chevy online manuals web site with no luck except that the number is listed as an acceptable for a rebuilt unit.
    thanks in advance for any help.
    Caleb
  2. Kens 50 PU
    Caleb, what year is your truck? My restopack shows the # as 1102710 for my '50 (not sure that that makes a difference). The restopack has a lot of info on the generator and voltage regulator. As for as output, i think it should be 35 amps on a standard, 40-55 on heavy duty. I stand at the ready to be corrected.
  3. Keystoner
    Keystoner Member
    Pennsylvania
    Generator Specs
    Caleb,
    This information is from a 1948 Pontiac with Generator Number: 1102701
    (generator rotates clockwise, 6 volts, Negative Ground)
    DELCO-REMY GENERATOR SPECIFICATIONS
    Generator output: 30 amps @ 2050 RPM
    Brush Spring Tension: 28 oz.
    Field Current at 6 Volts: 1.75-1.95
    DELCO-REMY REGULATOR SPECIFICATIONS
    Regulator Number: 1118242
    Cutout Relay:
    Voltage to close points: 6.4
    Reverse current to open points: 0-3
    Armature Air Gap: .020
    Voltage Regulator Setting: 7.4 volts
    Current and Voltage Armature Air Gap: .075 inches
    Current Regulator Setting: 36 amps
    -Tom
  4. Kens 50 PU
    Good info, Tom. Hey Caleb, go to www.stovebolt.com and click on the "Tech Tips" section. They've got some really good info on electrical there including a primer on electrical stuff on a truck. Good luck.
  5. calebroberts
    calebroberts Member
    Lyons
    I appreciate all the info - funny that it's an old Pontiac generator. No surprose - the truck is a '53 but the engine is an early 235 and I'm not sure what it came from. I should try to look up its numbers.
    thanks ya'll
  6. kyle
    kyle Member
    Cincinnati, OH
    i had a mopar heater in my 51, been there at least 10 yrs, but dont know after that how it made it in the truck. If i needed a heater i might do the same though
    ________
    Arab Recipes
  7. 54chevtruck
    54chevtruck Member
    West Chester,PA
    Ha Kyle, Back in the day they put in parts that would work did not really matter if it was a direct replacement. A lot of the early trucks got what ever the local garage or farm hand for that point could come up with. Like you said works for 10 years that's good enough.
