I have recently become in the possession of a truck that need some work. Unfortunately the truck had someone replace this motor with a 73 inline 6 engine and has rigged some things. So far I have replaced the cam and lifters and rebuilt the carb and had the head valves, seals, and guide all replaced and the head shaved.
The problem that I am having is the truck will just not idle smoothly, there are no vaccuum leaks either manifold or at the intake. The timing is correct and just seems to lack power mostly on the low end. Thank for any help you can give
