Installed Front discs
Discussion in '1947-1954' started by ronaldg, Nov 20, 2009.
  1. ronaldg
    ronaldg Member
    I now have front discs and now the original wheels are rubbing on the caliper and it looks like it is going to take a half inch spacer to clear them. I dont think thats the right answere I bought new firestones 6.50 16 inch tires a year ago Should i keep them or should i sell them and do something else. Any input would be appriciated.
  2. Guest5979
    Guest5979 Guest
    is the bolt pattern still six lug???
  3. ronaldg
    ronaldg Member
    bolt pattern
    yes it is 6 lug bolt pattern
  4. Zig
    backset?
    Hey Ron, could you measure what the distance is from the back side of the wheel (the part that meets with the face of the hub) and the back edge of the wheel you are using? I'd like to check mine and see if my original wheels have this same offset. Thanks!
    Paul
  5. ol' chebby
    It is rubbing with 16s? Wow you must have gotten the big brake kit. See what is rubbing on the caliper, some careful grinding......I mean clearancing...may be able to help. If you need spacers, lugnut king sells some nice aluminum ones.
  6. ronaldg
    ronaldg Member
    Spacers
    I found some spacers they are 1 inch wide And they clear nicely hope there ok they are the kind you bolt to existing hub same as the wheel 6 lug then then 6 lug to wheel. hope its safe and 1 inch out is ok as far as looks. thank for your input guys
  7. Zig
    If you have time...
    I'm really curious to know what the back offset is on your wheels, because I want to do the disc swap, but I'm not sure I want to use spacers. (Especially since these kits don't say to use them, or that they will be needed.)
    Thanks for your help with this if you can. I'm sure others are curious about this as well.
  8. ronaldg
    ronaldg Member
    backset
    zig the backset is 3 inches but i noticed that i have one wheel is slightly different It is very slight its the way there shaped on the inside of the wheel I didnt notice till now measuring it but they both rub on the caliper I tried half inch spacers they still rubbed so here i am with 1 inch spacers do you think theyl be ok .
  9. ronaldg
    ronaldg Member
    pic of wheel spacers
    heres similar to what i am going to use
  10. ol' chebby
    Those are the safest spacers to use, they don't stress the lugs as much.
  11. Zig
    Welllll~
    I finally got to measuring my backset (or offset~ whatever) and mine are 3 1/2 inches. So I'd still need at least 1/2 inch spacers.
    As far as 1" spacers~ I figured Russ would have an idea as whether those would work okay or not. That really stinks. I was hoping that you could just slap those wheels on there and sit back and beam.:(
  12. Zig
    One other thing...
    How can our host say, "May not work with original wheels.":confused:
    They didn't try these out before selling them? They include spacers in the kit, but they don't look like 1", which is what they would have found it they checked it out.
  13. ronaldg
    ronaldg Member
    wheels
    Zig 3 1\2 might work my wheels could be different than yours I think the shape of the rim where the caliper hits makes a difference My wheels are both different in the frot butt pretty close I have it looks like a little less than a half inch clearence now. remenber that i tried half inch spacer and it still rubbed so i went to 1 inch because thats what the guy had.
  14. Zig
    Anyone else?
    Anyone install 6 lug disc brakes and was able to put the "original" 16 inch wheels back on without spacers? (Evan?)
  15. vwnate1
    Tire Question
    Yes ;
    You should sell those bias ply maypops right away and get some LT radials in the correct size , wide white walls of course ! .
